DISTORTION OF GROUP WHEN ROTATED/MIRRORED
Not applicable
I've noticed that if I rotate or mirror a group in increments of 90deg, some of the
horiz/vert relationships are replaced with parallels. The result is that some of
the lines skew off of the hori/vert axis.
Is this intended?
Ron
Ronald W Latour
Re: DISTORTION OF GROUP WHEN ROTATED/MIRRORED
Not applicable
Ron,
This all depends on relationships of the objects with other objects. It
really has nothing to do with groups. All the group is doing is helping
select the geometry within the group. A group does not add any additional
constraints. Think of a group as an intermediate owner between the object
and the sheet.
Rick B.
