DWG files exported from DFT have callouts moved and flipped
We export dwg files for all of our sheet metal part draft files for our sheet metal shop.  We're on ST6, and do have the MP1 installed.  When the dwg files are opened, callouts are moving around. The arrowheads are still tied to the correct geometry, but the text moves.  In some cases, the text flips to the other side of the callout leader.  In other cases, we have one callout, then multiple other leader arrows that are tied to the main callout.  When the callout moves, the additional leaders does not.
The same issue exists in exported dxf files.
I've tried different settings in SEACAD.ini but none seem to correct the problem.
15 REPLIES 15
Re: DWG files exported from DFT have callouts moved and flipped
Dave,
You should log an IR with GTAC so they can investigate.
-Dylan
-Dylan Gondyke
Aviator
If all possible prints those drawings to PDF and send them that way, unless they need the actually 2D. We've found over the years that DWG's and DXF don't translate very well to other systems. Very rare we send out a 2D drawing, maybe wire burn..
Hello @TDB,
Hope you are well.
Is there any solution for the callout text moved issue in dxf now?
I am using ST8.
Aslam
Hi @Tushar,
Do you have any suggestion for solving the issue?
Aslam
Hi @aslam
This seems to be a bug and should have been addressed by now - 4 releases after it was first reported by the OP in ST6
Sorry, I have neither seen this nor any clue on how to solve.
Tushar
Hi @Tushar,
Thank you for your reply.
Hope it will be solved soon.
Aslam
Hi Tushar,
Is there any way to draw attention of proper authority so that they can take action quickly?
Can you do that please?
Aslam
I logged an IR back in 2015 for this when it started affecting the transfer of files to our customers. It looks pretty poor when a PDF and a dwg look completely different out of the same draft.
-Dylan Gondyke
Hi @aslam
You can add to the same IR that Dylan has logged so that more the number of people asking, it gets more priority is what I have heard.
Tushar
