DWG files with multiple layers issue
Hi Edgers,
I am facing the issue with a performance when I am working with the DWG files - imported from Revit/AutoCAD. After creating the SE drawing and implementing/placing in the DWG files, the SE performance decreasing dramatically, I would say 10 times slower.
After hiding all layers of this DWG file - performance coming back to normal.
Do you have any idea how to resolve this issue ?
Maybe would I ask someone to create a macro to swich off all the layers in one click ?
Thank you,
Arek
Production: SE ST10 MP8
Re: DWG files with multiple layers issue
Hi @arekkul
This can be done directly from Solid Edge by right-clicking on the layers group in the Edgebar.
Is that the little issue with layers or are you facing a larger problem with layers in the imported drawing ?
Tushar
Hi @arekkul
All layers can be hidden at once by right-clicking on the layers group in the Edgebar.
Tushar
Hi @Tushar
There is no option ( trying to right clic on the Draft Layer group ). Right click not working.
If you go down, you can hide every layer one after another only.
regards,
Arek
(view in My Videos)
Hi Arek:
You mentioned about importing a third-party DWG into Solid Edge.
But the video shows a layering structure which resembles the one generated when placing drawing views from a Solid Edge model, qith layers segregated per drawing view.
When I imported a DWG files with several layers, they all came in into a single "Layers" node which I can all hide or show by right-clicking.
I think I am missing something obvious or not understood the problem fully.
Tushar
You can shift-select or ctrl-select the layers under "draft", right click and hide, show or show only.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
Hi @Tushar
thank you for reply,
maybe I have explained wrongly - sorry.
Well, my problem is regarding to the video I have attached previously.
But, I am very interested how you did your DWG conversion - just one layer after.
Thank you for the answer,
Arek
Hi @bshand,
thank you for a reply,
I am using this method presently,  there is no other, better so far.
Arek
