Re: Dashed lines on coordinate dimensions
We have seen a lot of wierd graphics things here as people upgrade Windows 7 to Windows 10.  Always need to install the latest drivers for evrything including the graphics to fix.
http://Grundey.blogspot.com
Yes, I posted something about these awhile back. They fixed it though. I'm thinking you must be on ST8?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
I am on ST9 and saw it with MP6.
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
HI,
ST9 with MP7 - same
Wolfgang
I guess I've just seen it less because I started doing things different to avoid it. With me, it usually would happen after I double clicked a dimension. So I changed the way I did things to avoid it.
Solid Edge 2019
Honored Contributor
Honored Contributor
The same thing happens to me on every hole table where I have moved the label for the origin (every drawing set uses hole tables). I wish could set that up to never appear in the first place.
