Deactivate Parts in the ASM
Hello there,
I am in front of a problem. I hope someone can help me as i can´t find any discustions about it.
First of all i have made a Project for our customer. (File´s -> ASM). Now we had to update it and he wants a STP-File from the old version and the new one. Is there any resolution for deactivating psm/par from the asm for generating a stp ?
What i would not recommend - making a 2nd asm without the files.
What i have allready tried - Group the parts + Right click + Don t Show & Deactivate - Save As - xxxFilenamexxx - Type: .stp - open the stp file and everything is activated again.
I would appreciate it a lot if you could help me.
king regards,
Hämnmerle Ramon
Re: Deactivate Parts in the ASM
Hide the par e psm model that you can't show into stp file
File-->Save AS STP but first that you save the file select OPTION and select ONLY VIEW PART
Ciao
another Option would be to use configurations or Zones
2016-10-25 14_12_11-Solid Edge ST9 - Assembly - [Dateiname].pngZone2016-10-25 14_11_53-Solid Edge ST9 - Assembly - [Dateiname].pngDisplay Configuration
Greetings Chrsitian
