Default Bend R
Context: Sheet metal part, Ordered, Assembly driven part:
I'm wondering if there is a way to keep the "Default bend radius" box checked. Every time I start a new flange, I have to go check that box. I want to keep it checked all the time. To me, this is the purpose of a "Default bend R" but I have to go make it the default many times as I create a model.
One step beyond that, What controls what shows up in the box before that box is checked?
Re: Default Bend R
"Save Default" button on bottom right of Flange Options dialog.
http://Grundey.blogspot.com
Re: Default Bend R
This one was a "Doh" once I looked at it more closly.
