Default settings for drawing in 2D model?
I've looked through settings, while in 2D environment, and can't find where to set my defaults for drawing. It currently is default to drawing red phantom lines, and I'd like to change it. I can change it every time I open a file, but I'd like to find default settings.
ST8 MP9
Go FAST, or go home.
Re: Default settings for drawing in 2D model?
Esteemed Contributor
You need to set up your .dft template with the defaults you want. Open it like you would any draft, change settings you want as defaults, save the file.
You can set all the styles you want as default. See image.
There are template files for part and assembly as well.
Check the location your SE options point to for templates.
Bruce Shand
