Delete All USed Sketches in Sync at Once?
is there any method to delete all used sketches with one sngle operation instead of doing it sketch by sketch or selecting them together first?
This would be a  huge timesaver!
Wolfgang
Re: Delete All USed Sketches in Sync at Once?
A "trick" I use often to get  "clean" part or psm in Sync is to do a insert part copy.
It will loose all that "rubish" in the feature tree.. and you got a nice clean part.
It would be nioce to have this functionality in ST10..
Clean up.. forget how it was build...
Kind Regards,
Jan Bos
The Netherlands
