Delete line from rectangle?
N/A
i have downloaded soild edge ST4 to use for uni but everytime i select to install. it comes up with "the wizard was interrupted before solid edge ST4 could be completely installed"
i have changed the user account settings to the lowest but it still fails to install.
this message comes up instantly after i select install.
i am running windows 7 32 bit. my laptop comes well within the requirements to run the program.
Re: Delete line from rectangle?
Esteemed Contributor
Select the line/entity & press "delete" on your keyboard...
Solid Edge ST10 [MP6] Classic [x2 seats]
N/A
I had tried that before and for some reason the selected line wouldn't delete. Now it works fine. Probably something I was doing wrong. Thanks.
