Re: Delete, or not...
@Joris, I have no problem doing simple deletes with one or a bunch of selected text property fields using property manager.
Bruce Shand
The problem is still there in ST9:
I know I can overwrite, but select all and hit the delete button is a lot faster.
Solid Edge 2019 & AutoCAD 2019 user
In order to change the properties on those fields SE needs to change the parts. The fact that your draft views are not showing update lines means the files aren't being changed.
Bruce Shand
To be honest, I don't care about the who, what or where...
I change a value, I want SE to keep my change. Nothing less, nothing more.
(I feel a Mileti(r) moment comming...)
Have you tried replacing all with a period ".", a dash "-", or just an empty space " "?
Bruce Shand
All I can say, and I'm going to get out of here before you go full on mileti, is that I can do what you want without a problem.
Edit: and to amend my earlier post, the BOM should have an update line around it but not the views.
Bruce Shand
@Joris I see the combobox control appear when you click in the cells for that column.  Are you using the Propseed.txt file to display a List Of Values for that field?
Production: ST10 MP9, Testing: SE 2019
http://Grundey.blogspot.com
That's true. The dropdown arrows didn't register until you mentioned them.
Bruce Shand
If I replace each field seperatly with a "space" it is kept. If I copy this field and past over all the other files it isn't.
