Delete parts in assembly?
When I assembled subassemblies and then I want to delete some parts but I can not delete.
Not the same SolidWorks, I just click part and delete easy.
Can you tell me more.
Thanks.
Best Regard,
BuiTu
You must open the Subassembly for editing in order to del...
You must open the Subassembly for editing in order to delete these components. I assume you are in the top level assembly. Click on the subassembly, click edit-in-place, and then try to delete your part. When you are finished, end the edit-in-place and go back to your top-level assembly.
-Dylan Gondyke
Re: You must open the Subassembly for editing in order to del...
Thank you so much!
Best Regard,
BuiTu
