Design Manager Edit Path window missing ST9
My laptop does not display the Edit Path window when I am saving or renaming files and want to change the path. (Picure of window missing attached.)
Any suggestions on restoring it?
I have tried cascading windows and it is not there.
Laptop has been booted and issue is still there.
Same issue when laptop is docked and attached to multiple monitors or undocked.
Works fine on my desktop PC.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development
Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA
T +1 419 525 8554
gary.dinges@emerson.com
Re: Design Manager Edit Path window missing ST9
You can try to press the windows button on your keyboard and the arrow keys to get it back, or delete the registry key with regedit:
HKEY_CURRENT_USER\SOFTWARE\Unigraphics Solutions\Solid Edge\Version 109
(always make a backup if you delete something in the registry) and see if it comes back.
