Design Manager Question - Extract and change the name of a few parts only
Would you please to tell me how to replace the name of 10 files to different one in one go in new DM ?
I now how to do it in previous RM.
I know how to select / extract them amid the others but don't know what after.
Thank you,
Arek
Production: SE ST10 MP8
Re: Design Manager Question - Extract and change the name of a few parts only
I'm not sure exactly what you want to do but I will say I'm getting the impression that DM doesn't quite work as well as good old RM did. Especially when it comes to changing multiple files at once.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
I hope this help:
BR,
Imics
Hi Lmics,
As I wrote above I know how to rename one file after another, but how to do it having 200 files ? especially if you want to add for example suffix or prefix as a number. In OLD RM I was able to do it at once. Present I can't. ;-/
anyway...
Thank you for your help,
Arek
Community Manager
Select the target stuff in DM. Choose "Rename" command. Then use the "Replace" command (the replace text one -- over near find, not the replace document one). And key in the before and after text. I believe the need to choose the "Rename" command is new in ST9, because there didn't used to be explicit Rename and Move commands -- they were kind of "implied" by the Replace Text command.
Dan Staples
