Design Manager, Where Used, not indexed warning dialog
Every time we do where used we have to close this warning dialog.  Checking the "Don't show this again." checkbox has no effect as the "Yes" and "No" buttons are greyed out.  So we must close the dialog with the 'x' box in upper right corner.  Hase anyone else this problem with non-indexed locaitons?
Windows 7SP1, ST9, MP5
Those who know me question the assigned user rank.
Re: Design Manager, Where Used, not indexed warning dialog
I have the same "problem".. would be nice if this is solved soon.
Jan Bos
User since V3.5 beta testing ST10
Thanks Jan, likely not an isolated event. Just curious, does the beta perform the same way?
Is there a way to check if there is already an IR for this behavior? I tried searching the community before posting but found nothing related. Otherwise, I'll file my first IR.
Very not isolated...
the checkbox "Don´t show this again" works for me, until I restart SE. Then a window pops up again.
Ota
That's interesting. Different behavior. Are the buttons greyed out or must you close the dialog with the 'X' button?
I am sorry, I forgot mention that Yes/No buttons are active. I can "confirm" this dialog with click on Yes or No buttons with checkbox checked. It remebers this until SE app is restart.
Ota
update: GTAC has informed me that this behavior will be fixed in ST10.
