Design management: Open assemblies, DFT included
I need to check that all the parts and dft in a huge assembly are released. I always used the Design managment to do it part by part, but now it's going to be a pain in the ass (we are talking about 2.500). We don't use any PDM so... there's any fast way to do it?
Kind regards
J
5 REPLIES 5
Betreff: Design management: Open assemblies, DFT included
Hi @Jaume91
if You have ST9 or St10 and BiDM in use, then the Design Manager should do this for You automatically.
20180427_1044.pngRelease with Design Manager and automatical Where Used
Wolfgang
I see you have got what I'm looking for, but it seems is not working like that on my Design Manager
As you can see there is no DFT on my Design Manager assembly. What im doing wrong?
Hi @Jaume91
and this is where You should give Yourself the answer wether or not You are using BiDM - Build In Data Management?
Having "Fast Search" in place will bring the used drawing automatically, if not, then You need to do it manually.
Wolfgang
Ok, so that's it. I need to start using the Build In Data Management.
Thank you
J
Hi @Jaume91
welcome
Wolfgang
