Design manager and Where Used
Before ST10 when you did a where used in Design Manager you could select the locations to perform the where used
Now this is gone  and you cannot select these locations.
We have and old server (32 bits os) and this one is not indexed, dropbox is indexed.
What to do to get this selection of the location back..
Kind Regards,
Jan Bos
Betreff: Design manager and Where Used
Hi @Jan_Bos
if You turn of the Data Managment from within the Options, then You will be asked for the locations of the "Where Used" request
If Managment is on then SE automatically looks into the vault
Wolfgang
