Detail View Callouts
In an ST8 draft, Is there a preferred way to callout a particular detail view in multiple locations on the parent view?  Currently, I'm creating multiple detail views and placing them off the page, then renaming them.
Matt
3 REPLIES 3
Re: Detail View Callouts
To understand, you have multiple parent Detail View envelopes that all need to refer to one child Detail View?
http://Grundey.blogspot.com
Yes Sir...  That's correct.  Say you have multiple features that are identical on a part, but you only want one detail view.  I want to show multiple detail view envelopes in the main view.
What I've been doing is just creating multiple detail views outside the sheet and giving them the same letter as the one on the sheet.  Just looking for the best way to do this.
Matt
You could make a second detail, convert it to 2d view, delete the 2d view which leaves the "envelope". Copy this envelope to the other locations. Group them with their views if you want them to move with the views.
Bruce Shand
