Detail command
Not applicable
Having trouble getting detail command to work--it says to click for the center point of the circle but then does nothing.
Re: Detail command
Not applicable
The detail view command only works with Drawing views.
In your case a 2D Model view.
If you have a 2D Model view on your working sheet you can create a detail
view from that view.
Rick B.
"Brian.Lavallee@HutchinsonSSI.com"
wrote in message
news:Brian.LavalleeHutchinsonSSI.com.4t49fz@noreply.bbs.industrysoftware.automation.siemens.com...
> Brian.Lavallee@HutchinsonSSI.com's Profile:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/member.php?userid=313311
> View this thread:
> http://bbs.industrysoftware.automation.siemens.com/vbulletin/showthread.php?t=45367
