Detail view in Draft versus Mouse scroll
Hi Edgers,
I have got a question regarding issue I have noticed.
After choosing the Detail View in Draft the scroll mouse stopped working.
To close my view I have to use 3D connection navigator.
Is it a SE behaviour or an issue with the mouse driver ?
I have to admit - the scroll mouse is working okay in other enviroments within SE.
Thank you,
Arek
3 REPLIES 3
Betreff: Detail view in Draft versus Mouse scroll
Hi @arekkul
no this can not be reproduced here with Solid Edge - OK I have ST10 but I do not remember any similar behaviour
What exactly do You mean with "... I have to close the view ..." ?
What exactly is "CLOSE" the view?
YOu first only mentined "selected"
Wolfgang
Hi @hawcad,
I meant to zoom my view using mouse scroll.
regards,
Arek
The scroll wheel doesn't effect your drawing view at that point, but the drawing view scale drop down selection box.
In ST 10 this changes to the desired behaviour. (scroll = zoom drawing)
Solid Edge 2019 & AutoCAD 2020 user
