Details View
Not applicable
I want to make a details view but the fonction don't work!!!
I select the details view button, and circle detail view and when i want
to define the circle's center nothing happen !!!
Stef
Re: Details View
Not applicable
I'm guessing that you are trying to use the Detail View tool with 2D
geometry drawn directly on the Sheet1. The Detail View tool only works with
Drawing Views. Drawing Views are created from geometry drawn on the 2D
model sheet.
David
"stef" wrote in message
news:47af3859$1@bbsnotes.ugs.com...
> Hello,
> Stef
Re: Details View
Not applicable
Stef,
Detail views are scaled views of existing 2D Model views. You must have 2D
Model geometry on the 2D Model Sheet and then create 2D Model Views on the
working sheet from that geometry. Then you place the detail envelope on that
2D Model view. The detail view will be a scaled view of the bounded area
within the detail envelope. Changes made on the 2D Model sheet will apply to
both the 2D Model view and the detail view.
Rick B.
Re: Details View
Not applicable
Ok, thank you.
Stef
> model sheet.
> David
>> Hello,
>> Stef
