Developed surface
Does anyone have any work arounds for getting a 3D shape flattened so we can cut it on a CNC router?Foam blocker for port sheer strake.jpgFoam core shape in sheer
I can develop this manually, but that is kind of a time commitment.
Peter
Betreff: Developed surface
Hi @Greybarn
this shouldn't be any problem since Solid Edge is able to develope any surface to a flat pattern since ST7
You have to be within a part and finally You need to be in ordered mode.
Then go to extras where You also will find the flat model and here the second option (other than sheet metal flat pattern) the "platine body"
here you can select any surface or group of surface for which SE will create You the flat pattern of it
See picture
Wolfgang
What is this "Extras" tab? Is this something that SE Premium has?
Edit: Nevermind. It's "Tools"
Bruce Shand
Hi @bshand
exactly, in the English version of SE this might be the "Tools" tab.
This is nothing which has to do with premium , it should be there from Foundation upwards.
Wolfgang
So what I get when I use the "flatten" tool is something that looks like thisFoam blocker for port sheer kind of flattened.jpgFlattened, but not really....
Not sure why I can't get it lay completely flat.
Peter
Hi @Greybarn
could it be, that You have selected the wrong developable surface?
For me the picture looks like You have selected the side surface instead of the top surface.
You have to use those surface which should be flat afterwards.
Not the side surface You want to cut then as laser cut.
Wolfgang
Hi @Greybarn
here is a short video from above mentione developement
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Wolfgang
HI @Greybarn
just seen that I also have taken the wrong surface for my last picture
As mentioned it should be the top surface not the side one
Wolfgang
So here is the part I have modeled in my pictures. We want to cut these on a CNC table, using the widest face as the flat surface. If you look at the other faces, then you can see why we want to do that.
I have some other examples of triangular shapes, that we would like to cut too.
Peter
Hi @Greybarn
and what's about the red inner surface?
This IMHO produces a fine flat geometry, isn't it?
Wolfgang
