Dimension Subfix Tolerance
I created a hole dimension with a depth subfix.  Is it possible to change the depth subfix to 2 decimal places but leave the hole diameter at 3 decimal places? See attached.
David McMahon
Solid Edge 2019
HP Z2 Mini, Windows 10
Re: Dimension Subfix Tolerance
Unfortunately, no. That would be a good enhancement. The only way I know is to specify the tolerance on the subfix.
Bruce Shand
PLM World Member Genius PLM World Member Genius
If you use callout try:
%DI%{%HS/@3} x %{%HD/@2} DEEP
@cimarian, Seems like a nice trick but I get an error. Where do you find info on custom text strings?
Bruce Shand
Thanks. Can you make that callout work?
Bruce Shand
I attached a pic showing the dimension tolerance.
Oh, I made the mistake of not thoroughly reading your instructions and put in the dimension suffix tool where it apparently doesn't work.
Bruce Shand
Thanks for the feedback. That is a good work-around. I have submitted and enhancement request on this.
David McMahon
Solid Edge 2019
