Dimension Tracker settings
Does anyone know how to activate (make visible) the Current column for Dimension Tracker Window? Right now it shows only: ID, Element, Reason, Previous and Sheet columns. I remember I had it some time ago.
Marc
Re: Dimension Tracker settings
go up to the Sheet coulum and pull it to your right. i think it's hidden
I can not pull the columns to the left or to the right. I can only change the width by sliding the edge.
Exit Solid Edge.
Using a regsitry editing tool i.e. regedit.exe delete the following key:
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 106\PrefSets\Annotation
This should force a reset of the Dimension Tracker dialogs settings.
Should I delete the whole folder Annotation or a specific key inside. I see a lot of keys with the name starting with DimensionTracker
Yes you are right, it works now.
Thank You,
Marc
