Dimension Value is not showing instead alphanumeric value is showing
Team,
Hope you are doing good.
I am new user to Solid Edge community.
I have one trouble, In 3D model @ Sketch not showing dimensions value.
When I dimension any sketch, I can give/change the value by double clik. but after viewing dimension is not showing the value but showing some alpha numeric pls see attachement.
And suggest some option to overcome.
Thank you all in adnavce.
Re: Dimension Value is not showing instead alphanumeric value is showing
RMB on the Variable name and change to "VALUE"  I believe IIRC
EDIT:  screen shot added
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
I believe that you can right click on a sketch dimension value and select the Show all Values option to get what you want.
HTH,
Jason
Thank you sir for your Fast Reply. Yes you are right. And I got it.
And also, you can change that alphanumeric value to appear more friendly by double clicking on it or from the Variable Table.
~Tushar
