Dimension linking
Builder
Builder
How can I turn off the action of my dimensions (both in paper and model) locking or snapping together?
Re: Dimension linking
maintain alignment set
FYI..  for the most part this is desired.  if you only need to move one item  hold the ALT key and drag it...
you can also split and break alignment sets.
take a look at SE Help fir soem more tips: https://docs.plm.automation.siemens.com/tdoc/se/107/help/#searchSmiley Tongueage=1;rpp=10;query=alignment%20sets
