Dimension switch
Honored Contributor
Honored Contributor
Whats switch allows dimention text to get pulled outside (say above) the dimension line? I did this frequently in ST6, but have yet to find the switch allowing it in ST7.
Re: Dimension switch
Esteemed Contributor
ALT. It is used to do a lot of things with dimensions like detach/move connections to elements, add jogs/vertexes, and now in ST7, override dim text location.
Production: ST10 MP3
Testing: SE 2019
Honored Contributor
Honored Contributor
Thank you.
Working by my self, Sometimes I have to ask the simple things. I wish the serach in the on line help worked.
