Dimension
Does anyone know how to correct the dimensions have disappeared from the sketch? I can not edit?
3 REPLIES 3
Re: Dimension
Could they have been switched to "blank" somehow?
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
Bruce Shand
Re: Dimension
Hi guy tank you so much perfect!!!!
Re: Dimension
Hi @LuizQueiroz
Mark @bshand's post as accepted solution.
Looks like you have mistakenly marked your own reply as solution Smiley Happy
