Dimensioning to "Virtual Points" for sheet metal parts
I have searched the forum here lately and I have found no real answer to this problem.
When dimensioning formed sheet metal parts when bends are not 90deg seems to be a major pain. So far I can't make Solid Edge do it "intelligently". So I have attached a screen shot of a part where I ran into this issue and did my best to solve it.
I had to sketch lines, trim and etc to get the "Virtual Points" to where I could select them with my dimensioning tool. Then to get a dimension on the angled flange, I had to draw a parralell line to pull the dimension from. Next I had to edit the Scale Mode of the dimension to match the drawing view. After all of that my dimensions to "virtual points" read correctly.
I guess what I am asking is, is there an easier way of doing this? Because this kinda sucked.
Thank you,
Spencer
Re: Dimensioning to "Virtual Points" for sheet metal parts
Here is the other screen shot.
SeanCresswell 2nd Gear
2nd Gear
Hi there @SW,
I think all you need, is to go to Intellisketch Options.....and select "Extensions"
Does that do what you want?
Further......for dimension "Scale"...do this on the dimension ribbon bar, when placing them. I think the default value is 0.80, which AFAIK is a percentage of the active text font.
Solid Edge ST10 [MP3] Classic [x2 seats]
I already have Extensions checked in my intellisketch options. Does intellisketch control the Dimension tools?
2nd Gear
@SW,
Not explicitly....moreover, it controls/filters selection of entities, be that geometry creation, or dimension placement....."the trick" is, you need to mouse over the two edges that need to be extended.
After messing with it some more, I got the extensions to show up. It was definitely tricky but it worked.
Thank you
hawcad 3rd Gear
3rd Gear
Hi @SW
and don't forget the magic word "MICE"
  • M = mid point
  • I  = intersection point
  • C = center point
  • E = end point
You can use the "I" here to fin an intersection easier for use it with dimensions.
To orient the dim correctly to the direction of the flane just use "dimension axis"
Doing it in PSM IMHO makes it easier and faster.
See videos
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
and in PSM
(view in My Videos)
Wolfgang
hawcad 3rd Gear
3rd Gear
Hi Edgers,
just wanted to say, and retrieve the dimensions from PSM to draft brought me a little surprise with ST10  just now.
Only the angular 45 degrees dimension was/is retrieved to draft
All linear dims are not!
Can anybody confirm this?
Wolfgang
