Dimensions in 3D view on 2D drawing environment.
Just found another issue.
Can you tell me please how to add dimensions to 3D view in 2D layout drawing ?
Thank you,
Solid Edge ST8 MP10
Re: Dimensions in 3D view on 2D drawing environment.
Hi:
After you have picked the line and before placing the dimension, keep tapping n till you get it right.
For 'Distance Between', press <Shift> then place the dimension.
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
Honored Contributor
Honored Contributor
I have found that placing dimension can be effect by the point of view the dimension is placed.
But that's in the 3D environment. Once you have a 2D view, it can be imposible to get what you want. To work around that, I do the following.
I create a named view in 3D showing what is desired including the dimension. Then show that named view in the 2D draft. The problem is you are no longer using the drafting scales to control font size. The Scale/text game has started and can be a pain to set up right.
