Dimensions in worksheet
Not applicable
I have created a drawing on the 2d model workspace with dimensions on their
own layer. When I create a worksheet so I can scale for printing, the
dimensions disapear. How can I get the dimensions to show up on the work
sheets?
Tim
6 REPLIES 6
Re: Dimensions in worksheet
Not applicable
Tim,
The show/hide states of the layers in 2D Model defines what can be visible
in a 2D Model View on a working sheet. A 2D Model View cannot show more than
what is shown in the 2D Model sheet that it is defined from. So a layer that
is hidden in 2D Model cannot be shown in a 2D Model view. When a 2D Model
view is created, it inherits the shown layers from the 2D Model sheet. The
layers you see under each 2D Model View will only be the list of shown
layers on the 2D Model Sheet. Each 2D Model View may have a different set of
layers hidden in the context of the 2D Model View.
To see your dimensions, you must show the layer for the dimensions in the 2D
Model sheet. If you do not want to see those dimensions in a specific 2D
Model View, you can hide the layer in that view.
Rick B.
Not applicable
Thanks Rick,
I have both layers active in the 2D model. Still stumped.
Tim
"Rick B." wrote in message
news:4821b019@bbsnotes.ugs.com...
> Tim,
> than what is shown in the 2D Model sheet that it is defined from. So a
> layer that is hidden in 2D Model cannot be shown in a 2D Model view. When
> a 2D Model view is created, it inherits the shown layers from the 2D Model
> sheet. The layers you see under each 2D Model View will only be the list
> of shown layers on the 2D Model Sheet. Each 2D Model View may have a
> different set of layers hidden in the context of the 2D Model View.
> 2D Model sheet. If you do not want to see those dimensions in a specific
> 2D Model View, you can hide the layer in that view.
> Regards,
> Rick B.
Not applicable
I have it figured out.
One layer was called "Auto-hide" and when I changed it to "dimensions" the
dims appeared in the worksheets.
"tech" wrote in message
news:4823231e$1@bbsnotes.ugs.com...
> Thanks Rick,
> Tim
>> Tim,
>> visible in a 2D Model View on a working sheet. A 2D Model View cannot
>> show more than what is shown in the 2D Model sheet that it is defined
>> from. So a layer that is hidden in 2D Model cannot be shown in a 2D Model
>> view. When a 2D Model view is created, it inherits the shown layers from
>> the 2D Model sheet. The layers you see under each 2D Model View will only
>> be the list of shown layers on the 2D Model Sheet. Each 2D Model View may
>> have a different set of layers hidden in the context of the 2D Model
>> View.
>> Regards,
>> Rick B.
Not applicable
Tim,
Are the dimension lines there and you just can't read the actual text for the dimension
or is nothing at all showing up for the dimensions? No lines and no text?
Ed
"tech" wrote:
>Thanks Rick,
>Tim
>> Tim,
>> Regards,
>> Rick B.
Not applicable
Hi Ed,
Nothing at all was showing up. I was using the default layer names and
the "auto-hide" layer was the problem. As soon as I renamed it to
"dimensions" the dims appeared the the worksheets just like magic.
It seems that there are a lot of fine points not covered in the bulit-in
help file; if they are there I can't find them. It would be really cool
if they did something Wikipedia-like where users could enter things like
this into a database. I suppose keeping trolls out would be nearly
impossible.
Tim
Ed Kadlec wrote:
> Tim,
> Ed
> "tech" wrote:
>> Thanks Rick,
>> Tim
>>> Tim,
>>> Regards,
>>> Rick B.
Not applicable
Hi Ed,
impossible.
Tim
Ed Kadlec wrote:
> Tim,
> Ed
> "tech" wrote:
>> Thanks Rick,
>> Tim
>>> Tim,
>>> Regards,
>>> Rick B.
