Disable the "Rebuild Index" Button in SE2019
Is it possible to disable the button which Opens the Microsoft Indexing Options dialog box and rebuilds the index.
This button causes the index for the entire company to reset. The index is used by software other than solid edge, which means that other departments lose there search functionality for 3-4 days while the index is rebuilding.
Betreff: Disable the "Rebuild Index" Button in SE2019
Hi @AbANDIT
to create the index new on a server needs to be logged into that server.
So I must assume that a user who is allowed to log into the server will know what he does.
I do not think that a client indexing will force the server index to be rebuilt.
Wolfgang
Additionally, our recommendation for Solid Edge Data management and indexing is to not combine your Solid Edge indexing with other core functionality needing in your enterprise i.e. a separate server just for your Solid Edge data.
