Display Configuration Question
I have a good sized assembly (approx 3000 parts and 200 sub-assemblies within), and a display configuration that for example shows 50% of the parts spread through out the overall assembly. What I want to do is "reverse the state" of what is displayed, ie: show everything that is hidden and hide everything that is shown. I am sure there is probably a way to do this, even if it takes a few steps.
Any ideas or workflow suggestions?
Ross
Re: Display Configuration Question
Esteemed Contributor
Hi there @hyperset,
I do this regularly.....my work flow is to fence select all in the alternate config, the switch to the full config where you can hide the selected components leaving all else.....saving as a new config at that point.
Honored Contributor
Honored Contributor
Nice method to get an inverse selection.
Thanks, worked perfectly.
@SeanCresswell, That's a neat trick! I would have assumed the select set would clear when you pick another config.
An "invert" option in the right-click menu might be nice.
Bruce Shand
Betreff: Display Configuration Question
Honored Contributor
Honored Contributor
Hi Edgers,
AFAIR there was a macro by Tushar called ShowHidden which exactly did what You asked for.
Change hidden and shown objects from ASM
Wolfgang
Honored Contributor
Honored Contributor
... and here is the accroding link to the old thread:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Switch-the-display-between-what-is-...
Wolfgang
Thanks to all! Great community support.
Less than 24 hours after raising a question, I have a macro assigned to my Quick Access Toolbar that does exactly what I was looking for!
Honored Contributor
Honored Contributor
Hi @hyperset
those thanks belongs to Tushar, who provided this macro.
And Yes, this community really is a great place and a pleasure to belong to.
Wolfgang
