Distance Between
I'm trying to move a line using the distance between command and having no success.  This is hasn't happened very often and I can't figure out why.  I'm relatively new with Solid Edge.  I'm using ST5.  I'm going to upload the file.  Any suggestions would be greatly appreciated.  Thank you.
