Re: Distance between dimension text and feature control frame
Hi @Thomas_J
as said by @beachcomber
First turn ion the leader, position Your frame and turn the leader off.
As You can see in the video it perfectly connects the frame to the dimension text.
(view in My Videos)
BTW: I always and not only for frames recommend to have the leader shown when placing such an element.
If it is not wanted afterwards, no problem, turn it off.
Wolfgang
Thank you both, I understand what you mean now and it will work for me.
As an alternative I changed the properties for the dimension and set the text position to embedded instead of above, see video below. Then I can connect the box to the text and make it snap into to preset positions.
(view in My Videos)
