Distributing points eaqually along a line?
Not applicable
I need to distribute a number of points (more than 80) along a curved line. I want
them equally spaced but I don't know exactly how far apart they will be because
I don't know the precise length of the line, which is a closed loop of irregular
shape.
The points will be used as drilling locations.
Can anybody help?
Thank you
Richard Evans
Re: Distributing points eaqually along a line?
Not applicable
No way to do it.
http://grundey.blogspot.com
"Richard Evans" wrote in message
news:4790b528$1@bbsnotes.ugs.com...
> line. I want
> because
> irregular
> shape.
> Can anybody help?
> Thank you
> Richard Evans
Not applicable
"PellaKen" wrote:
>No way to do it.
Well, I've seen it done, although not with this software. I'm trying out as many
low cost CAD programs as I can and Free2D seems so comprehensive that surely there
ought to be some way around the problem.
Richard
>Ken
>> line. I want
>> because
>> irregular
>> shape.
>> Can anybody help?
Not applicable
The 3D product has the ability to pattern along a curve, but the 2D product
does not unless you write custom code to do it, and that isn't even an
option with the Free version.
news:4791d6c1$1@bbsnotes.ugs.com...
> "PellaKen" wrote:
>>No way to do it.
> as many
> surely there
> Richard
>>Ken
>>> line. I want
>>> because
>>> irregular
>>> shape.
>>> Can anybody help?
Not applicable
OK, thanks, need to look elsewhere then!
Richard
Not applicable
>Richard
I have exactly the same case, what a pity. Otherwise extremely good program. But
on points it lacks, also the point style cannot be changed except the linethickness
then
Frederik
