Do I need to uninstall before I do install?
Not applicable
Hi Edgers,
Could one of you help me with information about whether or not I will
have to uninstall an old V19 before I install the latest version V100(?)
on my computer?
Lennart
Re: Do I need to uninstall before I do install?
Not applicable
Lennart,
You cannot have two versions installed on your machine at the same time.
However, I suggest you wait on installing V100.
We will be releasing V102 shortly. I would wait for the release of V102.
The UI is significantly different from V19 to V100.
We have made some improvements to the UI in V102 from V100.
I will post a message on the newsgroup when V102 is released.
If you install V100 now, you will soon be a release behind anyway.
Rick B.
Not applicable
Hi and thanks!
Got an idea about when soon may be?
Lennart
Ricky Black skrev:
> Lennart,
> Regards,
> Rick B.
Not applicable
V102 should be released within the next couple of weeks.
Rick B.
