Doc. With an unused part
Good Evening Everyone,
I have a doc. With an unused portion... Triangle point highlighted. Is there a way of repairing or is not?
http://screencast.com/t/xoBk60Ew
Thank You All
Greg
There are plenty of ways of repairing if you go back into...
There are plenty of ways of repairing if you go back into the sketch and redraw it.......
-Dylan Gondyke
It appears you are in Synch mode and you are selecting re...
It appears you are in Synch mode and you are selecting regions... This is normal behaviour for any closed area of a sketch so I'm not sure what you think needs to be fixed.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
