Does SE drafting install some components to modify / access associated files even when not running
I have SE drafting (2D) installed.
I also use Lattice Semiconductor's Diamond tool, which uses files with *.par extensions. The sampe file extension is registered to SE.
Quite often, the Diamond complains that it cannot open autogenerated *.par file.
When I locate the file, it shows at SE file, with settable SE options. I cannot delete the file manually, but if I wait a couple tens of seconds the file disappears automatically.
Is this behaviour somehow linked to SE?
Can I disable it?
BR, -Topi
