Does Sheet metel Etch work in Ordered?
Innovator
Innovator
I'm able the create an etch in the sync mode but when trying in ordered I can't select the sketch elements on the plane of the tab.
SE
ST7
ver: 107.00.08.05
Steve
Tweeting @lussierinbox
Even the Longest journey starts
with a small step! Smiley Wink
Re: Does Sheet metel Etch work in Ordered?
Do you have a sample to share? I can make a sketch and choose etch just fine in ordered.
ST8 MP9
Go FAST, or go home.
Innovator
Innovator
Sure, I may be becuase I'm using contour flange....
Steve
Maybe the contour flange is the issue, I'm not sure. I went to your unbend and tried, no worky for me either.
ST8 MP9
You are very close to the solution. ;-)
You drew the sketch in the flat pattern. If you create the etch there it works. You only need to select "single" in staid of "chain":
After this you can select your sketch and the etch is made.
I don't upload the file because I work with ST8, so you can't open it.
Solid Edge 2019 & AutoCAD 2019 user
