01-27-2017 12:33 PM
For some reason I have lost the ability to align items when moving while drawing in Draft. I should be able to hover over an entity and dotted lines will confirm whether I am aligned to that entity, it's worked that way for years....
Now, no matter what I try, those lines are gone. I've hunted through all the icons wondering if I've shut something off, but I can't find anything that reactivates them.
Does anyone know how to get them turned back on?
Solid Edge ST8 - Draft
Solved! Go to Solution.
01-27-2017 12:48 PM
Alignment indicator is probably off.
01-27-2017 12:56 PM
01-27-2017 01:10 PM - edited 01-27-2017 01:15 PM
Do a command search for "alignment". I might have added it to the ribbon. Look in "all commands" in the ribbon customization dialog.
01-27-2017 05:28 PM
Found the icon, in ST8 it is on the Home tab, hiding on the far right...
01-30-2017 09:15 AM
Good deal. You can mark this as solved.
