Double click to...
How do you change the double click actions in SE ST7?
Double clicking a block should open the property text window not edit by default as other drafting programs do.
Double clicking a view in a draft should open draw in view not the model...
These seem like they should be simple to change to the desired action but my searching has come up blank thus far. Odd that this is an easy thing to do in autocad.
Re: Double click to...
I'm pretty sure you can't change that. It's just the way the program works....and how it always worked. I agree with you though, the "double click to properties" is way better....
Editability would be a nice enhancement.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
