Double pasting within Draft files
Hi. For some reason I still haven't figured out, every time I copy things within a draft file using ctrl+c & ctrl+v it will always paste it twice. This occurs when I copy something from a different draft file and also when I'm copying something from within the same draft file. Any idea why this keeps happening as it is quite annoying.
I'm running ST4 with mp12 installed.
Re: Double pasting within Draft files
Do you press Ctrl when you drag it? It make a copy
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
