Re: Download link of 2D Drafting ST6
Silwia,
At the Siemens website they only offer ST9 as far as I could tell. So I don't know where to download ST6 from.
Could you please advise?
Hi @KennyG,
How can i get the download link for Solid Edge 2D ST9?
I made the request but didn't receive any response so far.
Thank you!
Best regards.
@ManuelFelcorte  You would have received an e-mail I believe.  Check your Junk/Spam folder.
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Can someone provide a link to ST6 free 2D 32bit? I would greatly appreciate
i would also like a link to st6 32-bit for windows 10
You have save solid edge 2D drafting of old version? Can you share it, 32bit very need.
Just like at that time of you.
Thanks very much!
I made a request and got a link for download. The point is free license of the setup is expired and you need the license file they send with the setup link. Don't they send info anymore?
ST6 needs XP Pro or newer to run , does not run on XP Home.
I'll check if I can find the setup files.
Ok, and anyway, Thanks for you help!
You are good man.
Did you get an e-mail with download link and license file from Siemens? They respond fast.
I found the files by the way. If you did not get the e-mail I can share via a file sharing platform. I know how it is when you need a spesific software to work on a file but you can't find it anywhere. Since it is a years old free software I don't think It will be a problem for Siemens? Does it?
