Download
Not applicable
Please I need some help here. What I need to do to dowload the free 2d?
Re: Download
Not applicable
just go to www.free2D.com and register/download.
PS> not sure how you got in this newsgroup without doing so :-)
"Roger Silveira" wrote in message
news:474e1fd3$1@bbsnotes.ugs.com...
> Thanks
Re: Download
Not applicable
Roger,
Since you have access to the newsgroup, I assume you have been to the
www.solidedge.com/free2d web page and registered to download the software.
Is that correct?
If you had a problem with the download, you can go backto the web page and
register again. There is no problem with registering again. When you
register, you will be taken to the web page to download the software. Follow
the directions on the web page.
The file you download, SE2DDraft.exe, is an installation executable. Once
you download this executable, you must run it to install the software.
Follow the directions during the installation. If you have already
downloaded the executable, you should still have it and all you need to do
is to run the file to install.
Rick B.
