Draft: Add centerlines and marks to all?
Is it possible to add centerlines and centermarks automatically to a view in my draft, without selecting each hole and center manually?
Kenneth
Re: Draft: Add centerlines and marks to all?
Kenneth,
Yes you can do this.
simply click the icon automatic centerlines.(Maybe you have to do some settings ?.)
Or when you want to place centermarks you can simply place them by dragging a window around de holes where you want to have the centermarks
Dirk Rutten
Solid Edge ST6 user !!!!
That worked perfectly, thanks Smiley Happy
