Draft Issue
See video below.  I have a ghost line or something that I dont know where its coming from that I cannot delete or anything.  It prints too!  I need it gone without redoing that view.
(view in My Videos)
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
Re: Draft Issue
You might try a couple of things:
  1. Try to recompute the model if Ordered... Go to top feature and right click and choose "Recompute", Save, and return to draft and update views.
  2. If it still persists, go to the Drawing View Properties and on the Advanced tab, uncheck "Let Solid Edge determine VHL tolerance (recommended):" and set to a higher number.
If #2 fixes the issue, please report it to Siemens PLM or your VAR as an issue.
http://Grundey.blogspot.com
Re: Draft Issue
#1 done it!  gone I believe
