Draft Issue
A new issue has presented itself and Im not sure what is going on.  When in Draft mode, clicking on dimension tools, or the Prefix tool is giving me issue.  When I click on it, it makes Solid Edge "Not responding" for about 30 seconds and then its fine.  It is killing my productivity.
I have the latest MP (Version 4).  I have the latest updates for windows, graphics card.  I am running this on a Core i7 with 16gb of ram and a K1100m graphics card.  Its been running fine?  I have restarted a few times to only get the same issue.
Any ideas?
6 REPLIES 6
Re: Draft Issue
Any big Windows updates lately? There were Fall Creators Update issue months ago that caused lagging. What Win10 build number? If you are on Win10.
Bruce Shand
Re: Draft Issue
Hi there @lifofadrafter,
Hmmm, no real clue as to an answer......BUT, do you have your installation with all standard locations? I'm kinda thinking it might be related to accessing the Preferences folder, or something like that.
Re: Draft Issue
Re: Draft Issue
No, they are going to my local dropbox folder
Re: Draft Issue
I fixed my issue "I think".  I went through the "Settings & Preferences Wizard" and "Restored settings back to factory defaults.  I then went back and manually changed my settings.  I didnt want to copy the settings and restore them before you say that.  I wanted to ensure I didnt copy whatever was causing the issue.  It seems top be running correctly again
Re: Draft Issue
Excellent news!
