Draft envir... continuous lines appear as dashed
Builder
Builder
So I am hoping this is another easily solved, weird question...
Since upgrading to ST8, any lines I draw in the draft environment appear as dashed. The properties call it out as continuous and it will print as continuous, but on screen appears broken. I am quessing it's a display option somewhere but I can't find it.
Another request:
Will someone please explain how the new dimension handles work. I keep pressing Alt+drag to relocate a dimension like I did before and it isn't working.
Thanks so much. You guys are great!
Michele
