Draft name... Why the type is automatically saved
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
Re: Draft name... Why the type is automatically saved
Bonjour Alexandre,
Le problème semble nouveau depuis ST7 MP2.
Voir la discussion suivante:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/ST7-MP2-source-extention-in-dft-file...
De mon côté, j'ai un problème semblable avec la fonction "Save As Translated".
J'ai déjà loggé le problème (PR 7231888).
Il faut simplement espérer un "fix" bientôt.
Michel
Community Manager
As Michel says in French, this is a bug in MP2 which is obviously very disappointing. We are looking to turn around a fix quickly, but in the meantime, the only solution is to workaround or roll back to MP1.
Dan Staples
Thank you guys for your quick reply.
Merci Michel
