Draft of mirror assembly in loop
Hi everyone,
I'm working with an assembly in which half of it is generated using the mirror command.
In the parts that compose the assembly are many part copy and many interparts relationship.
When I try to make a "drawing of active model" command, Solid Edge begins the procedure but at some point it stops and remains stationary, seems looped.
Has anyone been in this situation?
What happened?
